Firmware 3.04.37 problems
0 replies · 1,337 views · Started 12 September 2005
I had my 3 branded 6680 upgraded to the above firmware today. To my supprise, the new firmware was 3 branded as well, the 3 tech support had told me it would not.
The update was done at a Nokia Service Center, not part of 3.
My first impression was, that the memory handling had indeed improved, I can still get up to 7.000 KB free even with several memory resident programs (Lifeblog, Agile Messenger and Nokia HS13-W drivers).
Lifeblog, however, won't start at all. I un-installed the old version, installed the new V1.60.06, rebooted but still no luck.
Attempting to start Lifeblog results in a return to the menu with no visible sign that Lifeblog has started.
Bluetooth also appear flawed, possible worse than before. Connecting and disconnecting a couple of times to my Nokia Carkit 1 appear to kill Bluetooth, I have to restart either the phone or sometimes restarting Bluetooth will do - before I can connect again.
Anyone else running Lifeblog and 3.04.37 ?
Regards
Michael
