Program for backing up Nokia 6600 - Contacts, messages, calendar etc?
4 replies · 11,138 views · Started 13 September 2005
Hi
I'm looking for a program, that is able to backup selected data (contacts, SMS, calendar etc.) through BT or IR on my N6600. The phone needs a reformat really soon.
I can neither user PC Suite nor the built in "backup to mmc" feature, as both of them just back up and restore ALL data.
I'm looking for a solution that lets ME select which data to backup and restore, and I'm not looking for a "make a sync with outlook"-solution.
Anyone who knows a program that can be used? Doesn't matter if it's free or commercial software, it just has to work!
You can use the data mover feature in the PC Suite to extract the calendar and contacts from the device.
I made a backup of my 3650 using PCsuite. I burned it on a CDR. It is still on my laptop but when I tried to restore it..the PCsuite said �this is the first time the cellphone is connected here and no backup is made�I cannot restore the phone memory but it�s saved in my laptop and CDR with file extensions .dat Can someone help me please????How can I restore my phone memory which I made and saved from a CD? All my contacts and pictures were on the phone memory then.Thanks!!! 🙄
I know some applications.
Smart V Card--Contacts
Message Saver--Message
I'd used these 2 programmes for several months, it only costs a little space on your memory.
If u really want the applications, u can try to find it.
Hope that it could help u.
thanx man for the info!
i have made backup of my messages throgh message saver.
how can i restore the backup i-e put them back in the set?
is there any other software that does this (backup ALL messages including sent, drafts etc and then restore them when necessary)
