Are there some conversion functions, which can retrieve from an TBuf8 buffer the TInt32 and TInt16 values?
I am trying to parse an residual SIS file (which was probably created using RFileWriteStream class) and I want to read the whole content of the file to an TBuf8 buffer using RFile class and after retrieve data, which I need. It is usually a length or a pointer to some data inside the file coded as TInt32 or TInt16 value.
Example of one TInt32 value and one TInt16 value:
buffer: 0x03 0x00 0x00 0x00 0x08 0x00
TInt32 value = 3
TInt16 value = 8
To avoid this problem I tried to use the RFileReadStream class, because there are already functions to do that (ReadInt32L(), ReadInt16L(), etc.). But in this case, I was not able to read several times from a specific position of the file. Always I had to close the file, open it again at the specific position, read the data I needed (e.g. another pointer), close it, open it again, etc...
If both are possible, which solution is better?
Thanks a lot for any help...
Because I didn't find any better way, I created simple functions to get the same functionality for my buffer as it is available when you use the streaming functions.
I have created following functions:
TInt readInt(const TDes8& buf, TInt offset, TInt numBytes) {
TInt result = 0;
for (TInt i = numBytes; i > 0; i-- ) {
result *= 0x100;
result += buf[offset + i - 1];
return result;
}TInt readInt32(const TDes8& buf, TInt offset) {
return readInt(buf, offset, 4);
TInt readInt16(const TDes8& buf, TInt offset) {
return readInt(buf, offset, 2);
Now I am able to read the whole file to a buffer and to parse it after according my needs.
Usage example:
_LIT(KSisFileName, "c:\\system\\install\\Test1.sis"😉;// Open a RFs
RFs aFs;
User::LeaveIfError(aFs.Connect());
CleanupClosePushL(aFs);
// Open a file
RFile file;
file.Open(aFs, KSisFileName, EFileRead) ;
CleanupClosePushL(file);
// Read the file
TInt iSize ;
file.Size(iSize) ;
HBufC8* buf = HBufC8::NewL(iSize) ;
TPtr8 pBuf = buf->Des() ;
file.Read(pBuf) ;
// Parse SIS file
TInt num;
TBuf<60> numBuffer;
num = readInt32(pBuf, 0);
numBuffer.Num(num);
iEikonEnv->InfoWinL(_L("UID 1:"😉, numBuffer);
num = readInt16(pBuf, 20);
numBuffer.Num(num);
iEikonEnv->InfoWinL(_L("Number of files:"😉, numBuffer);
num = readInt32(pBuf, 52);
numBuffer.Num(num);
iEikonEnv->InfoWinL(_L("Files pointer:"😉, numBuffer);
// Close the file
CleanupStack::PopAndDestroy(&file);
// Close the RFs
CleanupStack::PopAndDestroy(&aFs);
Maybe it can help someone ...
skauting wrote:Because I didn't find any better way, I created simple functions to get the same functionality for my buffer as it is available when you use the streaming functions.I have created following functions:
TInt result = 0;
result *= 0x100;
return result;
Usage example:
RFs aFs;
// Open a file
RFile file;
// Read the file
TInt iSize ;
file.Size(iSize) ;
file.Read(pBuf) ;
// Parse SIS file
TInt num;
TBuf<60> numBuffer;
numBuffer.Num(num);
numBuffer.Num(num);
numBuffer.Num(num);
// Close the file
// Close the RFs
I also struck with the same. If you get the answer can you post it here
