It can be put in the movil a tone of call MP3?, for example, to put a tone MP3 that I have in the memory card.
Tone of call MP3??
If I understand you correctly, you want to use an MP3 as your ring tone?
This is not possible on the Sendo X, and never will be possible.
You can convert the MP3 to wav, then you can use it
Some other format? or single wav?
peconrrixico22 wrote:Some other format? or single wav?
Existe un programa que se llama Quodrings que reproduce archivos OGG Vorbis, adem�s tiene la funci�n de poderlos usar como tonos, cuando entra una llamaba toma el lugar del tono normal, tarda un segundo antes de escuchar el tono y elimina la alarma vibratoria, esta en Beta, as� que puede que no funcione del todo bien, pero por lo mismo es gratis, y seg�n los desarrolladores es 100% compatible con el Sendo X, yo no lo he usado as� que ser�a todo lo que te puedo decir.
Por cierto lo bajas de http://www.quodsoftware.com o bien de http://www.handango.com/PlatformProductDetail.jsp?siteId=1&jid=75EDD87E1F3X1F16DD26A29CXEEF1582&platformId=4&N=7&productId=149411&R=149411
Sorry for being rude and reply in spanish, but my fellow Sendo X user is from the mother land Spain, well here is the tranlation in order to make it helpful for everybody
There is a Ogg Vorbis player for the Sendo X called Quodrings, which is like OggPlayer but it has the extra to use the ogg files as ringtones, the only issue is that it takes a second before you hear the ogg file, and the vibrating alarm is off, the program is in beta, so is possible it will not work fine, but because of that, the software is free.
You can download it from http://quodsoftware.com or from http://www.handango.com/PlatformProductDetail.jsp?siteId=1&jid=75EDD87E1F3X1F16DD26A29CXEEF1582&platformId=4&N=7&productId=149411&R=149411
No pasa nada porque yo soy espa�ol, porfavor dame tu correo en un privado o algo porque tengo muchas dudas sobre el telefono.
A ver si me ayudas.
