Can someone please tell me if I can get Window Media Video Files to play on the Real Player that comes pre-installed on the Nokia 9300?
If not is there any easy to use software that converts wmv's to rm files?
Cheers
Rich
Cheers
Rich
No, the Real Player on the 9300 cannot play [Microsoft] Windows Media Video files.
rramsden wrote:Can someone please tell me if I can get Window Media Video Files to play on the Real Player that comes pre-installed on the Nokia 9300?If not is there any easy to use software that converts wmv's to rm files?
Cheers
Rich
I dont know if there is but you can convert .wmv to .avi and then .avi to .rm using Real Producer.
eshahwe wrote:I dont know if there is but you can convert .wmv to .avi and then .avi to .rm using Real Producer.
Then you can use Quicktime Pro to convert to .MP4,
This is how I've had to do it,
Carl,
