Hi first time poster here got a problem with my 3650. Started running really slowly a got memory full message. Did memory scan only had 1kb left on phone memory but couldnt find where all the memory was being used, so did a soft format on phone. Seemed to work untill i tried putting my 256mb mmc back in. I now get system error message when i try to do anything, so i am now using the phone without mmcand it is terrible without all the stuff i had saved on it. Can anyone help please . Thanks
mmc problem on nokia 3650
EvilStilo wrote:Hi first time poster here got a problem with my 3650. Started running really slowly a got memory full message. Did memory scan only had 1kb left on phone memory but couldnt find where all the memory was being used, so did a soft format on phone. Seemed to work untill i tried putting my 256mb mmc back in. I now get system error message when i try to do anything, so i am now using the phone without mmcand it is terrible without all the stuff i had saved on it. Can anyone help please . Thanks
It is recommended to format the memory card as well because it has references to the phone. (Installed applications) All will work well afterwards. 😊
Kamalayan wrote:It is recommended to format the memory card as well because it has references to the phone. (Installed applications) All will work well afterwards. 😊
Thanks for that, can i formatt the mmc in another phone then put it back into mine, as my 3650 will not function at all with the memory card in 😊
I Need To Know The Folders On The Mmc Card Can Anyone Help
thanks again formatted both memory cards in another mobile and they both now work well in my 3650 pity about the fact i backed up all my phone memory on the larger card and then lost all info because they were no longer compatible after the phone was formatted. let that be a warning to all 😊
