HELP!!!Font and Installation Problem...6681
0 replies · 1,668 views · Started 15 September 2005
:icon14: Thank you for your help in advance.
I am working on SMS application for a Unicode-based Ethiopic scripts. I am using Sun wireless toolkit(Ktools). I could customize the default J2ME emulators for Ethiopic. The application, therefore, works very well using the customized emulators and a Unicode font installed in Windows XP.
Now, I want to install the software on Nokia 6681. But, I face the following problems.
1) I tried to install the application on 6681 using PC interface cable-Nokia PC Suite. An icon representing the application and its name appears in the main menu of the phone. However, the application blinks with white interface only once and quits authomatically. I can't get the application working (It doesn't run properly).
2) Now, I would like to test the application on j2me toolkit using Series 60 Symbian emulator. For this purpose, I download Series 60 MIDP SDK 2. I can run the application using this emulator. However, I can't get the unicode Ethiopic font working on this emulator. The font works on a customized default j2me emulator. But, the unicode true type font installed in XP doesn't work on this symbian emulator.
Thank you for your help on the above two problems again.
