Hello,
My organization is looking for an easy way to distribute an everchanging contact database for our nokia phones. I was wondering if anyone knows of an easy way to do this..? for example a way to download a contact list using your cellphone? any other way?
I've searched the web for answers but found none, thought this hive of expertise might be the place to ask.
Thanks in advance,
Rotem Tamir
Not exactly something you can download as you would have to replace the contacts file, however one phone can be programmed with a contacts details and this can be send as an SMS Business card to all the others which the user can then save to thier phone. Might be something to look into, to do it you go into the contacts and send them as an sms, this creates the business card and you send it to who needs it.
Duke.
