I have used S60 Theme Studio to create themes,
I have successfully created the themes and have the sis files on my pc, now when I try to Install them on my 7610, i get a message which says : cant Install.S60scalableSkinSupport Required.
I can easily install all other themes, just not the ones that i have made,
i Unsis'd the files and i found that they contain 3 files (the usual.mbm and .skn but also a .mif file) whereas, the other themes which i can install easily have only 2 files, the mbm and skin file,
i am using the same steps as my friend to create the themes, and it works fine for him,
what do u think the prob is??
someone plz help!
Prob Installing my own themes!HELP!
I believe you created the themes with Series 60 Theme Studio 2.0. It makes themes for newer phones, like the N90. Use Series 60 Theme Studio 1.21 for the 7610.
