- Legacy for UIQ - critical display bug: possibly firmware caused, or... ?
2 replies · 3,022 views · Started 16 September 2005
Hello,
At game startup, several seconds later, the Legacy-Loading white screen image shifts away and stays that way in the game. I've noticed that the buttons are in their place though, meaning that even though the image is shifted up/downwards, if you want to click on something on the screen you have to do it on the spot it should normaly be done at. :icon4:
The tested files were Legacy 1.05.2 and 1.05.1, with multiple reinstalls and fresh installs, on both c: and d: drive, and clean wipe of any legacy related files (all of them, i hope) before reinstall on c:.
Phone - P910i, CDA162005/ R5A02. :redface:
note. Redshift(.hu) manufacturers' reply to my email was that the problem is rare (a very small few unfortunates/month), inexplicable, and possibly firmware related("?"😉.
Do any of you guys know how to fix this/what may cause it?
.all the best! :icon14:
I never had problem with my P900 but since I got my P910 last year I got same problem as you :frown: So far not heard any solution of the problem. Also got same answer from Legacy support as you.
Old question that might not need an answer anymore..? But I having my own solution to this problem, if any interested then let me know.
