hi can nokia 6680 be used on a cdma network?? or is it just gsm?? and is there a way i can convert the phone to cdma??
thnx
and another question...is it just mine cell, or the reception just sucks...like talking on it is fine... like it is superb...but when i see other nokia(not same model), same service provider, they have more signals then me, n should i have my network mode to gsm or dual mode?? see when ever i am in a concrete building, my cell shows 3g sign...hmmm is there a way to improve the signals,
thnx let me know asap....thnx....
I'm afraid the answer is no. The 6680 works only on GSM/WCDMA networks and not CDMA (and there is no way it could be modified for CDMA either).
Dont worrie when it says 3g at the top it means that you have full normal recption and the bars refer to how much 3g recption you have
no the thing is i dont have bars...lol...i remember when i had ngage, n when i used to go to my basement, i used to get 1 or 2 bars...but with this one it is only 1, and that is when i stand close to the door....but ngage was getting better reception...n is there a way to turn up the vibration in the phone, sometimes it rings, n sometime while walkin i dont feel anything, so i get missed calls.....
one more question...the office that i got with ngage, can i type on it, like if i get wireless keyboard...or do i need to get another software for it...
anyone???? anyone know the answer??
