I made a theme and its pretty dark because i wonted bright blue text but i can change the base text color... anyone know if that can be changed?
See what i mean...
See what i mean...
It cant be changed,you will have to use a lighter desktop image,or lay a highlight over that one. 😊
I'm using theme studio ver.2 and to change the font colours I think u can do it from the COLOURS tab on the left side. Scroll thrugh the options and you'll find it. If that is not helping you then I don't know other way. :tongue:
You can only change the font colors in these areas softkey/status/navigation.
Not the application text,which is the problem above. 😊
The colour of the text used in the application it can't be changed, but the colours of
the text used in the theme is changeable throug the COLOUR tab in the Studio. 😃
zlatko_k wrote:The colour of the text used in the application it can't be changed, but the colours ofthe text used in the theme is changeable throug the COLOUR tab in the Studio. 😃
it could be done on theme studio V2.0 (Series N) but not on theme studio v1.2 (Serie 60 Symbian above 8) 😊
