headphones of any kind possible for X700?
0 replies · 2,530 views · Started 19 September 2005
I got third party software to work fine (OGGplay), I can convert the mp3s and not lose quality and space, that all works fine. How do I listen to it through headphones, I wanted to use my own headphones but, and I had to get a adaptor first cause the heaphone jack was too small but even then I only got sound in one ear, is that cause it only gives mono sound? and if so isn't there a way I can get the mono sound playin in both ears? Also if thats not supposed to work would bluetooth headphones make a difference to get stereo sound, or I just basically want sound in both ears, it doesn't have to be stereo sound. There are lot of bluetooth headset clips out there from iTech which u can plug ur own headphones in but I'm wondering if those will even work with the X700 or give me any sound?
If you can answer any of these questions it would be most appreciated, thank you.
