Does anyone know hoe to delete delivery reports after you have sent a message. when i enter my reports folder and click on the report the only option i get is call.
can someone help?
can someone help?
You cann't delete them.
The only way to do is to reset you phone, but then you will lose everyhing
what f**kin idiot thought that was a f**kin good idea
stupid F**kin NOKIA
phew good thing I never switched mine on 😃
You need to goto LOG, then go to the right by clicking right with the joystick, then goto OPTIONS then CLEAR LOG
that will get rid off your delivery reports, also all the data regarding calls, SMSs, GPRS sent and recieved!!!
Hope this helps!!
thanks mate jus did it
that was pissin me of for while
thanks alot
You are most welcome!!! 😉
It was tickin me off for a while as well....until I figured it out!!
i had to phone up club nokia to find that out
[quote="tvoung"]phew good thing I never switched mine on 😃[/quote]
yeah, tell me about it!!! im even surprised i never turned mine on, im sure i must have missed it. because had i not, im sure i tested it out!
