GMail on P910i
2 replies · 3,575 views · Started 20 September 2005
Is it possible to download e-mail from Gmail as POP3 onto the P910i. I connect and it just keeps processing without doing anything. I have another POP3 e-mail account which works fine, but only 10M storage, so not practical. Any advice?
Not natively, you need profimail or something similar, as although the device supports the secure connection that gmail uses, the built in software doesn't
seanob wrote:Is it possible to download e-mail from Gmail as POP3 onto the P910i. I connect and it just keeps processing without doing anything. I have another POP3 e-mail account which works fine, but only 10M storage, so not practical. Any advice?
I haven't got gmail to work per se, but I can pick-up and reply to gmail. I simply forward on all gmail to a regulat pop3 account. Just change 'reply to' settings and all is seamless. Not elegent, but works.
