Hi guys, long time no see, well my last post I have a 3650.
Well now I have a 6600 and I've installed Face Wave (now FaceStore) trial version from the original site.
Facestore it's an app to send animated MMS with your voice. I did exactly what I should do: install sis file then reboot, then a new option appeared on Messages > Create Message > Facestore Message
When I open my messages and tried to create a new MMS with facestore nothing happened, and worst: after uninstalling it my MMS doesn't work anymore! I can't even change the settings, neither old MMS on my phone can be opened. I can't send or receive MMS.
I send a mail to Handango and they ask to contact Openbit support, and I'm waiting for the answer.
Other features on my phone works perfectly but I think they will ask me to format.
If i press the *#7370# command I will return to factory settings, so what about another stuffs on E? Like my MP3 and shortcuts for other programs installed on E? They will disappear and I must reinstall everything again?
I used the search tool to avoid make an double thread but I didn't see anybody with the same problem. Please help!!
