Memory Card Locked
2 replies · 5,772 views · Started 20 September 2005
Hi
I have 6600 mobile.My memory card got locked iam unble to remove the password form the memory card. I don't want to earse any data on the card. Is there is any way to remove the password.If So can you please suggest me the same.
I have even tried the to find the mmsstore file tat to is not working.
In my understanding if you can't find the file with the password in using FExplorer or it's not there then the mmc can't be unlocked by conventional means. You may be able to try one of the specialist memory recovery firms online (a quick search on google should help you with this) although i believe they are quite expensive and results aren't guaranteed. I also believe this topic's been answered numerous times throughout the various forums - a quick search would've revealed this.........
