Cell Info display on 6680
3 replies · 2,571 views · Started 21 September 2005
I have just purchased a 6680 on Vodafone (UK). On "Active Standby" mode, the cell info displays for about half a second then vanishes, which isn't terribly useful! On the normal standby screen it displays permanently, as it did on my 6230 and 6310i before that. Does anyone know if there is a solution for this issue? (and don't tell me to stop using Active Standby 🙄!)
hiltonian wrote:<snip>cell info displays for about half a second then vanishes, which isn't terribly useful! On the normal standby screen it displays permanently<snip>
😡 I get exactly the same problem, but it has appeared since a few days only (i have that phone since 6 months). Additionaly, you will notice that UMTS cell names are not displayed (not anymore in my case), and the last difference is, in stand by, the antenna level meter doesn't indicate data not connected <....>, but only indicates data connected <=>. The 3G indication gets smaller when a connexion is alive. It used to remain the same size, 'course.
All these changes happened suddently. I thought Celltrack could have caused that, but the author guaranteed me that can't be. I even tried a hard reset. I lost everything but this bug. 😮
Luc
Yep. I got mine updated (version 4.04.07), and still the same. Even worse... the cell name doesn't appear at all, even without Active standby...
