yftp
4 replies · 1,138 views · Started 22 September 2005
Hi long time reader, first time poster here!
Ihave recently bought a 6680 on orange in the UK
I am trying to use yftp to connect to my home pc ftp server.
Unfortunately i cant seem to get the phone to connect. 😞
I cant seem to find the correct settings on the phone client software to allow me to connect.
I know 100% that the pc ftp is working perfectly, i know that i have the correct login and pass on phone, but it always cant connect and terminates.
Am i missing something ? Is it an orange UK problem? Is there a tutorail or walkthru anywhere? Will i go mad b4 i get this to work ????????
Thanks😊
Do you have Orange's Internet Access Point settings? Are you using that access point with yftp (and not, e.g., a WAP Access Point)? Do you have a plan/subscription that allows full Internet access? Can you connect to some other FTP server or does it fail, too?
N/A wrote:Do you have Orange's Internet Access Point settings? Are you using that access point with yftp (and not, e.g., a WAP Access Point)? Do you have a plan/subscription that allows full Internet access? Can you connect to some other FTP server or does it fail, too?
thtanks for he reply 😊
it wont connect to any ftp at all
when i attempt to connect i have a choice of 3 ways to connect orange gprs wap, orange internet and orange mms i have tried all
also im not to sure about the settings in yftp for server name do i need the full path ,ftp://whatever.com, or leave out the ftp:// bit??
Lol takes me 5 seconds on a pc but im struggling here 😊
thanks for your help
enzero wrote:thtanks for he reply 😊
Try usinf fttp:// instead of ftp://
No. "fttp://" doesn't mean a thing. And if you are using an FTP-program, then don't use the "ftp://" either (it is only used with browsers).
