I bought a 6680 on 3 IE.
When I am roaming on vodafone, it still displays 3.
When I search for networks I pick up the following:
(3G) 272 05 [3 IE]
3 [vodafone IE (2.5G)]
(3G) O2 - IRL
METEOR
The USIM must replace 27205 with 3.
I wanted to set an Op Logo for Voda and 3 to display on-screen instead of just "3"
In C:\system\sharedata\100058ec.ini there is an option, "ShowOpLogo=0"
I assume that I need to change it to 1 but I am not able to copy the ini file off the phone nor can I overwrite it with an edited copy of the same file from Z:.
I created a backup using Nokia Suite but when I edited the file, using a hex editor and also notepad, on both occasions the file was not accepted by N.S and could not be restored to the phone.
I also created a backup using the "memory" app, which created a file called backup.arc, but I am not able to extract it.
Can I just edit the arc file with a hex editor and then restore it back to the phone?
Is there a program that I can get that will allow me to change "ShowOpLogo" and "OpLogo"?
