Nokia 9500 WIFI Problems
1 replies · 1,942 views · Started 23 September 2005
I've a problem with a 9500 wifi conection.
I don't know how to connect a notebook with wi-fi connection to my 9500.
I need to connect the 9500 communicator to my notebook with wifi for internet connection but when I try to perform a search from the notebook, it doesn't find the communicator and when i try to find the notebook from the communicator, I can't find the notebook.
Do you know any way to connect the communicator to the lan wifi without using a router or switch for internet connection?
(The connection must go from communicator to noteboOk!)
Thanks.
make sure your notebook is set up to ad-hoc.
then use your communicator to search for ad-hoc networks, that should do the trick
greetz
TS
