Hi all,
Was just wondering if I could get your advice. Its nearly time for me to upgrade my phone again and I have no idea which one to get. The last two phones I've had are the Nokia 6600 and nokia 6630, so I want the next one that has the same functions and more basically.
I know at the moment its the 6680 but the only thing thats basically different to that one is the two cameras. Does anyone know if there is any other smartphones that have had great reviews? Or if theres any coming out soon?
Any help would be appreciated.
Cheers
Christian
Well, i luv 3230 very much although i'm using 6600.
It's cheap and worth compared to the other phones.
A multi-feature phone but it lacks of 3G and wi-fi features.
You might want to consider looking at the Nokia N70, which is just hitting the shops. Its a N-Series phone, and is the next one on from the 6680.
Also consider there are always more phones round the corner 😊
I'd go for the N70.
I have just upgraded from the 6680 to the N90, the hi res screen is nice but slows the phone down quite a lot and is quite big and cumbersome with all it's twisty modes 😉
but the hi res video recording is AWESOME.
I think the N70 will be perfect compramise as it has the same screen as the 6680 so should be just a fast and has the hi-res video recording of the N90 and has a radio thrown in too.
I think my N90 might end up on eBay once the N70 hits the stores
Go for it 😊
OK cheers for your advice. I've been reading up on the n70 and I think this will be the perfect replacement. Although theres talk that it won't reach the shops until December?!
