Hi all,
Im new here as I just got my 7710. So far I seem to like it and all is fine with it.
I was wondering, those anyone use or know how to use the 2 LINE function on it?
Any help will be appreciated.
Medube
Hi all,
Medube
medube wrote:Hi all,Im new here as I just got my 7710. So far I seem to like it and all is fine with it.
Medube
well it's easy.. 😊 on the screen you'll see the network logo its look like a wire, left side to the network indicator.. if you want to use line 2 just simple tap to the network icon/logo.. it will notify you that you are using line 2 or 1.. do the same if you wanna use line 1. 😃 good luck :icon14:
Hi nunu90,
I know that part, IM asking how do you get 2 sims in there or do I have to get network to put 2 numbers on 1 sin or do I have to use a dual sim adpater? Thats what I was actually asking 😊
hahha...
if that's what you ask for.. i give up :rock: 😃
anyone could help him.. ?? :wavey:
nunu90 wrote:hahha...if that's what you ask for.. i give up :rock: 😃
did u find answer to ur question yet?
thnx
Hi..
i think line 2 doesn't mean 2nd SIM ...coz firstly there aren't 2 SIM slots!!
Wirelessly posted (SendoX/1.0 SymbianOS/6.1 Series60/1.2 Profile/MIDP-1.0 Configuration/CLDC-1.0 UP.Link/6.3.0.0.0)
U must buy dualsim adapter in my country,poland,cost some 20 euro
