will sendo pc connect work with nokia pc suit
7 replies · 3,396 views · Started 26 September 2005
I have a bluetooth dongle which works with Bluesoleil 1.6.1.4 software.I read nokia pc suit 6.6 supports this software , is there a possiblity to use nokia pcsuite for connecting sendo pc connect.Please help me out .Else please let me know some other way to connect through bluetooth dongle
It should work with Sendo PCC, provided you've got an old version of m-router installed. Is your bluetooth adaptor RFCOMM or WIDCOMM based? Also, don't forget to set up your Bluetooth serial ports as well...
Latest Nokia PC Suite will, indeed, work (or should work) with Bluesoleil/IVT.
However, Nokia PC Suite will not have any impact on Sendo's PCC sw ability to work with Bluesoleil/IVT; Sendo PCC must have the BlueSoleil/IVT support in itself (or Bluesoleil/IVT must he fully compatible with some other Bluetooth stack the Sendo PCC supports).
In other words, installing Nokia PC Suite won't help Sendo PCC to start working with Bluesoleil/IVT, if it doesn't already.
Iam not sure wether its Widcomm or Rfcom based, i tried installing widcomm software for this dongle but i get some license error , and a message saying shutting down bluetooth stack.With the BlueSoleil/IVT i tried seting the ports but dint succeed :frown: .
does any mrouter supports BlueSoleil/IVT stack , i tried mrouter 3.1 and it dint work
Well thats great news.....glad to hear it works for you.
Have u tryed accessing the internet via bluetooth??........works like a charm.
So you have connectivity between ur X and PC Connect now??
bhrij wrote:Well thats great news.....glad to hear it works for you.
Yeah iam able to connect to pc connect now, thanx a lot , i have been trying this for a long time 😃 .U made it look easier for me 😊
