Hi All
i got a bad serios problem in my 6630 and looking for any advice.
the problem is my phone's screen got alot of horizontal lines with one vertical green line and the colors gitting worse i don't know why the phone got confused
and its never droped down or got hitted ,
but i installed fscreen caller 3 pefore i got this prob.
any body have any idea how to fix the problem or just tell me is it hardware or software
any one can help?????
peace
my nokia 3560 also has horizontal lines on the screen and it is apparently a LDC fault. also instaling dogy or free applications may have viruses or compatability problems causing the phone to fault in many ways
Hi
r.armadillo wrote:my nokia 3560 also has horizontal lines on the screen and it is apparently a LDC fault. also instaling dogy or free applications may have viruses or compatability problems causing the phone to fault in many ways
Thanx r.armadillo for your reply but i didn't mean the normal lines of the screen
what i ment exactley like the lines of the forum logo
but its colored lines (green and blue)
I hope u understand what i ment
Peace
Listen To The God Damn Advice, You Installed Some Dodgy Software And Maybe Got A Virus Now Just Reformat Using, *#7370# But Be Warned All Info Anjd Progs On Phone Will Be Lost It Will Be Like You Just Bought It Make Sure You Save All Contacts To Mem Card First.
specter wrote:any one can help?????
You are screaming so loud that your phone gets so scared and develops those nasty coloured lines.1 :tongue:
UA
