so whts my password..?
10 replies · 6,612 views · Started 27 September 2005
Are u forget about ur mmc password? Get the mmcpwd. If still error, maybe ur mmc is corrupt and this is what u have to do:
Corrupted MMC fix
Necessary tools:
- Corrupted MMC
- 7tools partition manager (get it from: geocities.com/rulirahm/symbian/7tools.zip, the demo version is capable of carrying out this task)
- Pair of hands
- little brain but not necessary
lets do it
Part one
Put your MMC into your card reader, select the MMC
If your partition is corrupted you will see several invalid partions in red in the left hand pane (MMC drive section)
Right click each of these and left click delete.
Click apply (top left button)
You should be left with a single free unit on your MMC drive. Now right click that unit and select create primary partition. Go with the defaults which should be FAT16 and click on apply.
Exit and put your card back into your N-Gage. If you find that the MMC card still does not mount via the USB cable (That is if it was mounting prior to corruption). Unplug the cable and put your MMC card back into your card reader.
Part two
Start the 7tools and select the MMC again.
In the right hand pain you will see a column that says Active (it will probably be set to "no"😉 click this and set it to yes (That take a few MB of your MMC but it makes it an active bootable drive partition), click apply
Put the MMC back into your N-Gage and format it via tools-memory-[options]-format mem card.
You will notice that the card is a couple of MB down on it original size but it will now be fully bootable and functional via the USB cable again.
Keep in mind:
If u formatting MMC card trough windows u could fuck it up if you format in any other partition than FAT, no other partitions like NTFS, FAT32, don�t work!
Thats it, astalavista bay
Hope this help
yes i forgot my mmc password.
dont have mmc reader or usb connection.
ive got ivt bluesoil bluetooth.
so does tht mean theres no way?
thnx anyways
super_dunkaroos wrote:yes i forgot my mmc password.
thnx anyways
But, u still can install app mmcpwd.sis, aren't u? Sorry, I've checked the links and its broken. Get it from here
symbian-freak.com
Find at the left windows on that page. It was called MMC Password.
or u can d/l from my site: http://geocities.com/rulirahm/symbian/mmcpwd.zip
Do u mean that u can't turn on/use ur ph? Try this :
Boot in safe mode: hold the pen/pencil key while ur phone is boot/start until it turn on (with mmc/without mmc)
A new virus just come that make ur mmc disable and create random password on oit. Read this: http://www.symbian-freak.com/news/1005/Cardblock.htm Maybe that was ur problem.
If ur phone can't start/turn on with the safe mode, there is no other way, u've to take it to the nearest nokia care centre(ncc) at ur city.
no no this is not a virus...
the phone is just fine..
the readme file says this software has only been tested on two sets and the ngage qd is not among them.
.....help........... : (
super_dunkaroos wrote:heres wht i got from the mmc file:
 000000 �|2� . a d
and no the password is not 000000...soo wht is it?
can i get this software?how to get it?
