I got a problem adding new applications to favorites. :frown: I tried to do it the way it is described in the manual but there is no such "Add to favorites" option in the menu. I also tried some thirt party apps to do it but they obviously store the shortcut to a wrong directory - the impact is none. So doesanybody have any clue how to do it? Any software that can do it? Any idea where and how the shortcuts are stored. Thanks a lot.
Problem with favorites
Use AppMan :icon14:
The "Go to" or "Favorites" app is almost useless as it comes, because applications need to specifically have built-in support for it, and few do (of even the original apps on the phone).
SymbianWare's AppMan, as mentioned can help you there, if you want: http://my-symbian.com/7650/applications/applications.php?fldAuto=234&faq=2
Personally, I never use it and just move it to the bottom of a submenu with other stuff I never use, either.
