How to delete picture msg folder?
6 replies · 2,394 views · Started 13 November 2002
yes, how to delete picture msg folder in the images section?
thanks
[quote="someone999"]yes, how to delete picture msg folder in the images section?
thanks[/quote]
you cant. this file is in the Z drive (browse with seleQ) and files here are read only and ya cant delete em...
please correct me if im wrong, i promise i wont mind... 😃 😃 😃
[quote="seanmiguel"][quote="someone999"]yes, how to delete picture msg folder in the images section?
thanks[/quote]
please correct me if im wrong, i promise i wont mind... 😃 😃 😃[/quote]
waaa..
sean u r so fast in replying 😃 😃
[quote="Pichu"][quote="seanmiguel"][quote="someone999"]yes, how to delete picture msg folder in the images section?
thanks[/quote]
waaa..
sean u r so fast in replying 😃 😃[/quote]
if you spend about 8hrs (i think this number is even less compared to other members) everyday in this forum, this can be the result! gee, it even affects my work!
the default picture messages are also stored in c:\Nokia\Images\Pictures and are 256b each, so hardly worth removing. They are all present on the z: too in the same path. (i guess for when you reset the phone?). If you delete the entire directory 'Pictures' then it is re-generated by the phone (folder only).
