This is a very simple fix for the charging bug caused by later versions of Agile messenger.
Using FExplorer go into Processes > find the process called "AGILEAUTHSERVER " and kill it.
Now still using FExplorer go into C:\System\Programs and cut the "AGILEAUTHSERVER.EXE" file and paste it into C:\Systems.
You dont have to keep the file but i recommend you do just incase.
Well enjoy the fix......please give feedback whether this fix works or not or any problems u face.
so, Bhrij, tell us how long HAVE you been running the program this way? 😉
something new? lol
thanks for the fix - pure genious
Excellent, thanks a lot!
I had worked out which service was causing the problem, but hadn't got round to trying to delete the file 😞
Mordred 660 wrote:so, Bhrij, tell us how long HAVE you been running the program this way? 😉 something new? lol
lol......sorry guys.....but i have been running Agile like this for a few months now.
So its not something new :redface:
Sorry for the major delay in getting this fix posted....call it Time-to-Post delay.
Many thanks for the fix, exits a lot of frustration... :icon14:
Doesn't seem to be working for me. It will be loading for ages (trying to start AGILEAUTHSERVER.EXE I guess) then it will show me an error message and when I press ok it will shut down the programme.
Was the latest version
