hi..
where can i find a screensaver for 92XX??? any programs?? :roll:
Screensaver
none so far. :bday:
This matter was brought up before, and I don't see the point of a screen saver. It's not required as the 9210 has an LCD panel, and as such can't phosphor burn. The screen turns off after a few minutes to save battery life anyway. Maybe for a 9210 a screensaver should be called an "Energy Waster".
Yeah I want a screen saver, I was going to download a few skins from n9210i.co.u but that website is DEAD 😞 , and if you buy smart display you can have the screen on for as long as you want. 😃
Does anyone have example screens? I would liek to make some of my own, I just need a size example :roll:
Someone was working at it...but I agree with Switchblade. The screensaver has no use! But if the app was free... 😉
😮 FREE applications! 😮 😮 😮 😃
Hi there. I'm new here on this forum. Hope I'm welcome. I would also like to know if there is any place where you can get free apps for the Nokia 9210i.
I'm from South Africa, and it looks like I will never get any apps here.
If anyone can help, would be gladly appreciated.
http://nokia.warlocks.be
http://www.freepoc.org
and check our site(AAS, this site) software listing for freeware apps.
[quote="Anonymous"]Hi there. I'm new here on this forum. Hope I'm welcome. I would also like to know if there is any place where you can get free apps for the Nokia 9210i.
If anyone can help, would be gladly appreciated.[/quote]
Indeed you're wellcome....as Dazler suggested,spend some hours browsing aas and you'll find lotts of cool free apps... 😉
