Okay guys, I am completely new the the Symbian platform. I am looking to purchase a 6682 for work/personal use and I want to know the capatability (good/bad) of the Nokia Suite software with Microsoft outlook.
Any and all help is welcome..
No flaming please 😉
Cingular is currently the only carrier to sell the 6682, on Amazon.com right now you can buy the phone for 99.99 AR with new contract. You can ofcourse check out ebay.com and get an unlocked one and use it with the carrier of your choice (xcept sprint)
It works very well with Outlook. The key is you have to move your phone contacts to a sub-folder under your main Contacts folder. Then in the sync advanced tab you need to select this subfolder to sync with.
Otherwise it is very straight forward and I use it daily. Very simple
