write protected mmc?????????
5 replies · 8,439 views · Started 29 September 2005
i bought a new 256mb kingston dv rsmmc for my 6630 but when i put it in my memory card reader and try and put a file on ot it says its write protected but if i keep the mmc in the phone and connect via data cable transferring works 😡
menhel wrote:i bought a new 256mb kingston dv rsmmc for my 6630 but when i put it in my memory card reader and try and put a file on ot it says its write protected but if i keep the mmc in the phone and connect via data cable transferring works 😡
I ahev the exact opposite problem.
i ahev a kingston 512mb dv rsmmc. My cardreader reads it fine & writes to it fine. But when its in my 6630 I cant write to it 😞 no installing sis nothing!
One way to solve this problem is to Format the Memory card in the phone and name it something different to what you had before ie: MemCard, Mem, Memory.
Then you should be able to have complete access to it in a card reader and it won't be write protected.
