TDK USB & 7650.... on Win98SE anyone got it working?
1 replies · 2,101 views · Started 13 November 2002
I can see the 7650 and transfer files to it... but I can't establish a proper connection..
Each time I try and set up the serial link I get "Unknown Port" from the BT explorer on TDK on the Nokia PC Suite side I cannot see a COM0 (which is what TDK is assigning) I do see a COM4, however when I select it - after a short period is complains that something else is using it.
Anyone able to help? My plans for tonight is to try and fully un-install _everything_ then slowly reinstall BT then PC suite..
Cheers,
Bret
HAve you Tried, Enabling the power switch, then in the task bar right click on the bluetooth icon, select configuration (i think, if not that try the other "system"😉 unclick all the bluetooth boxes then retick them all. Then switch on bluetooth on your phone and send a picture to your computer or vice versa and a connection sould be made hopefully : 😃
