does anyone know where I can get the latest firmware for my Sendo X? The offical sendo webpage is offline since one week or so.
My phone needs the Vodafone firmware, which is not available at www.sendosmartphones.com.
Thanks for your help!
Remo
ritel wrote:Hi,
My phone needs the Vodafone firmware, which is not available at www.sendosmartphones.com. Thanks for your help!
Remo
The firmwares are now unlocked meaning u can use any firmware on any Sendo X. It does not matter whether its vodafone or anything else.
bhrij wrote:The firmwares are now unlocked meaning u can use any firmware on any Sendo X. It does not matter whether its vodafone or anything else.
Thanks for the fast answer. I tried the Expansys UK and the European BE firmware and both did not work. I can start up the phone, but when is comes the NOW screen, the application crashes and the phone can not be used.
Any ideas what to do??
ritel wrote:Thanks for the fast answer. I tried the Expansys UK and the European BE firmware and both did not work. I can start up the phone, but when is comes the NOW screen, the application crashes and the phone can not be used.
Reformat ur phone........hold down the 5 key and siwtch on the phone........then clear the memory.
This will destroy all data stored on the phone.
also do not restore from a previous save - you will need to start from scratch unless all you are doing is restoring your data.
i would still recommend doing everything from scratch.
Thanks a lot! That worked ....
The instructions on this forum and at Sendo Smartphones explain exactly how you should upgrade to the latest firmware. Everyone should read those instructions before attempting to upgrade to the latest firmware.
