hi guys, can anyone tell me what is causing my 6600 to display the warning "App. closed Main!" every time I start my phone? Will reformatting my phone solve this bug?
My other problem is that I have a hard time sending text msgs. The phone displays a msg saying it can no longer send txt msgs because the memory is full even if I still have a few MB of memory left. I can only send an average of 7 text msgs before the warning appears. The only way I can send msgs after this is by having to restart my phone. Then the whole thing repeats.
Any idea on how to fix this thing? thanks in advance.
Did you format your phone recently?
Or
Did you install any application/game recently?
How much space is left in your phone memory?
hangaya1178 wrote:
my pone got the same prob(app closed main) and i formated the phone by using the trhee key thing that is to press and hold the
green key
star key(*)
key number 3
press and hol this three keyes and swicth your phone on and hold till you get the masage formating.it takes about 1 miniut to coomplet and after formating your phne will work corrcetly
thats for sure cozz i have expirienced that
Wirelessly posted (Mozilla/4.1 (compatible; MSIE 5.0; Symbian OS; Nokia 6600;452) Opera 6.20 [en])
kayong wrote:hi guys, can anyone tell me what is causing my 6600 to display the warning "App. closed Main!" every time I start my phone? Will reformatting my phone solve this bug?My other problem is that I have a hard time sending text msgs. The phone displays a msg saying it can no longer send txt msgs because the memory is full even if I still have a few MB of memory left. I can only send an average of 7 text msgs before the warning appears. The only way I can send msgs after this is by having to restart my phone. Then the whole thing repeats.
Try reflash with tornado
Not sure, but this sounds like a program that auto starts and then fails for some reason (fault, not compatiable with phone etc.) Try uninstally recently installed software.
