Anyone know if there is an Adobe Reader for the 7650 (or anyway of reading PDFs)?? I want to use it for reading ebooks.
Adobe Reader
Web viewer is able to read PDFs but only online ones!
Hmmm...could be a tad expensive that way 😞
doesn't handy book read ebooks?? i thought it was...
correct me if i'm wrong !!
ebboks yes, pdfs no!
ah okay! thanx
Hopefully there will be some kinda PDF viewer! But honestly thinking of the size - It might be better to view through the web!
There will be a PDF reader for Series 60 devices, but I don't think it will be released until the 3650 arrives. I sent an email to the maker of PDF+ for the 9210. This is what I got back:
> Do you have any plans of porting your software to Nokia's
Symbian-based Series 60 platform?
I have indeed susch plans and I am working on implementing them too. The problem with the current device (Nokia 7650) is that it is a little short on memory so there will not be much PDF files that can be stored on the device.
Best regards
Sander van der Wal
www.mBrainSoftware.com
Looking forward to it!!! There is a discussion going on somewhere else regarding MEM lacks - Some see it as an idea to use part of the SIM card as MEM. Hopefully that will be possible some day....
