ok , the device worked well for a while , and now - i tried to install something , anb B00M - it don't
when i start it .. it asks for the pin code .. i type it , and the device gets stuck ..
i can press anything .. after 3 .. 5 secs .. it restarts its self .
so i can't do any
*#7730#
or
*#7780#
i was told that there is a "hard rest code" that formats c:\ on the n-gage.
it should be a combintion of some buttons .
anyone knows it ?
no button combo, deactivate your sim pin by putting your sim in another phone, put it back in the ngage, and try putting in *#7370#
mob453 wrote:no button combo, deactivate your sim pin by putting your sim in another phone, put it back in the ngage, and try putting in *#7370#
dude ..
u don't understand ...
the sim code is not the problem .
the problem is in the n-gage.
it is STUCK .!.
There is only one way to solve ur problem without take it to the 'NOKIA'. Boot in safe mode: hold the pen/pencil key while ur phone boot/start/turn on until it really turn on. If it work, then u can type the code *#7370#. If not working, there is no way, u've to take ur phone to 'NOKIA'. Good luck 😊
Wirelessly posted (NokiaN-Gage/1.0 (4.03) SymbianOS/6.1 Series60/0.9 Profile/MIDP-1.0 Configuration/CLDC-1.0)
U must have heard of uiq reset combo of pressing answerkey&key3&key* as u start up.But doubt it works for ngage.Try starting without mmc installd,then hard reset (*#7730#) then reinstal card & format card.I think u downloaded some dodgy app.If that fails,u'll need to take it to service cen'a for "flashing"
