Hi there,
i have a stupid idea for a application, but this depends on how much throughput the 7650 can achieve over a bluetooth connection using the serial-port-profile...?
i know that bluetooth itself handles something like 700-750kbps, this would be more than enough for my needs,
but i'm not shure if this will be the rate i can get, 'cause when transfering images/files, whatever to/from the phone the speed is much slower... so i guess due to processing power or power consumptions, the bluetooth throughput has some limitations...
sooo... anyone every tried to send data as fast as possible over bluetooth from 7650 to a pc...? which rates did you achieve...?
Thanks for your Help!
