internet on my laptop via gprs
0 replies · 5,694 views · Started 03 October 2005
I've tried to use numours bits of vage info i can find to set up a connection to use gprs form my n-gage to access the internet ON MY LAPTOP. So far i havn't got it to work. The furthest i got was setting up a connection dialing *99# gprs starts on my phone but i cant access internet on my laptop (internet explorer, msn etc)
To do this I...
installed bluetooth software>installed nokia modem options>created a new connection on my laptop(input ISP payandgo.o2.co.uk and dial number as *99#)>in nokia modem options gone into modem then slected my modem and gone into advanced and entered extra initial commands as AT +CGDCONT=1,"IP","payandgo.o2.co.uk">paired my phone with my laptop>opened the dial up connection and connected to phone>gprs starts on my phone>connection is complete but internet is not accessible on my laptop.
Ive also tried using *99***1# which connected the same as *99# but non of the others like *99***#2/3/4 will connect.
I had a go at the pdf file on the disc on how to set it up but its stupid, it just stops at like a dead end (doesn't get u anywhere)
Personally i think i need to change some settings somewhere because the connection is working but i just can't access the internet, im a bit of a noob so i wouldn't know where to begin changing these settings.
Original Nokia N-gage with O2 300 free texts pay and go sim card
Wap/GPRS accessible
Toshiba Equium A60 laptop Windows XP
Widcomm Bluetooth Dongle
A step by step guide wouldn't go a miss but that is doubtful and asking a lot. So if anyone knows what i need to do to get this connection working correctly your help will be much appreciated. Thanks alot.
