telnet/ssh for 7650?
13 replies · 2,927 views · Started 13 November 2002
Does anyone know of a telnet/ssh program for the 7650? I think it would be really usefull...
thanx
[quote="Yug_r"]Does anyone know of a telnet/ssh program for the 7650? I think it would be really usefull...
thanx[/quote]
coming soon...
also wait for Commodore64-client and SID-player...
[quote="-jb-"]anyone actually got mutelnet to work properly?[/quote]
Nope, I only got as far as the login prompt then couldn't seem to type
I got it to work... just one problem.. where is the enter button??? 😃
In the help it says right, but it seems thats for another phone...
thanx anywayz..
[quote="mrcommodore64"][quote="Yug_r"]Does anyone know of a telnet/ssh program for the 7650? I think it would be really usefull...
thanx[/quote]
coming soon...
😊[/quote]
Sounds good want to give us any more hints 😊
Rafe
[quote="CiaranMcNulty"][quote="-jb-"]anyone actually got mutelnet to work properly?[/quote]
Nope, I only got as far as the login prompt then couldn't seem to type[/quote]
I have the same problem 😞
[quote="Yug_r"]I got it to work... just one problem.. where is the enter button??? 😃
thanx anywayz..[/quote]
or more like this problem maybe..
Telnet on 7650 is one of my big desires (the 1st is NetMonitor...).
Yes, the "Enter" button is to move the joystick to the right, and it worked in my case, but never succeded to connect to any telnet server :cry:
http://s2putty.sourceforge.net/download.html
The above link contains source-code for Symbian OS, compiled for Symbian Series 60 and 9200 Communicator.
Don't know if it works for the 7650, but it may work.
In any case you can always check the source-code and rebuilt it to suit your phone.
I am in the middle of rebuilding it to suit the keymap for Siemens SX1.
Last time i checked it didn't work on the 7650 because it runs Series 60 0.9 and Putty is compiled using the Series 60 1.2 SDK.
