Sound Quality and having to restart the N-Gage HELP!!!!!!
8 replies · 3,660 views · Started 05 October 2005
😡 I have just bought an N Gage QD and have found for know reason the sound goes very quite (even on loud speaker). I turned off the Mobile and on again and it all worked fine. I also found that not only could i not here very well but when i was on voice mail, if i pressed buttons on the phone to access options it did not register. Anyone else herd of this? 😡
Wirelessly posted (NokiaN-Gage/1.0 (4.03) SymbianOS/6.1 Series60/0.9 Profile/MIDP-1.0 Configuration/CLDC-1.0)
Hello wright.U seem messd,and u shd b aftr spendn yr hard earnd and its not workn.Yr problem is either hardware or sofware;first,i had a code that enhances your clarity of sound(but i have to track it down-gimme 60mins)called half rate codec but eats battery.Otherwise,to check if its sofware prob,u may need to format phne(punch *#7370# then default code is 12345) to restore z drive info.Wait for phne to restart(1st make sure batt is not empty) And yr phne SHOULD work,if after that it doesnt,THEN thats a hardware fault so if yr guarantee period aint ended u may need to go fight for yr rights-rodney king style to get yr phne fixd/replacd fr free.If they make u pay,pay then have yr boys visit the manager at home with baseball bats!Let me kno how it goes,good luck
I almost forgot!Before u formatt backup yr contacts(either manually write them out) because format wil ERASE All info added to phone aftr purchase(bye bye to apps & all yr sms txts)hope am not too late.Now let me check for that half codec code...
I do appreciate this mate, i was tearing my hair out! No, havent reset it yet! I guess i could just take out my phone sim and put the N-gage one in then reset? As i said it was odd, as after i tirned the phone off and on again it worked fine?
Wrigit this aint yr night.Cant find the code an tis 2300 here,my eyelids heavier than pamela andersons bust,so i'll get bac 2 u 2moro mornin.Goodnte Goodmrnin or Good-whatever whereever u r.Over&out.
BREAKING NEWS;Just met a bloke frm our mini ngage community here and if i didnt know im bettr,id have sworn he was u for he has the exact same prob. With his ngage classic.We tried "my" method of charger start,that failed,and (so i bet that it didnt fr u,innit?)so did a host of others(leavin out battry for long,changn sim,mmc...)the 4ne wudnt go past the nokia logo(talk about a sleepn pill overdose!)til last resort was to take it for the infamous flashing.After 15 minutes 😊 &10 US$ 😞,technician handed us the fone good as new,save for well scratchd casing&pornclips on mmc(which isnt affectd wen u flash)he claimd prob was downloadn dodgy apps(warez or incompatible apps) to phne memory.Hope this helpd.Let me kno how it goes.One love.
Well I tried the master reset and that all rebooted fine! It seems to be working ok, even though I'm sure it went slightly quite yesterday, but I may have been imagining that! I'm going to stick with it for a while, see how it goes! Have you managed to hunt out that sound code yet?
