This headset (works well) has a standard power supply with a 4" long adaptor cable to reduce the power jack down to a tiny socket on the headset. I believe the part may be CA-71. Guess what - I've lost the adaptor cable. Does anybody know where I can get a replacement? My local Service centre can't get one.
Thanks very much....
I'm kinda winging this a bit, since I havent tried that particular headset yet, but is the power plug the new 2.0 mm Nokia standard?
If so, Nokia makes an adaptor from the 3.5 mm of your ACP-12 charger to 2.0mm that might solve your problem. The model number here in Europe is CA-44. Try asking your dealer for that one.
Alternatively there are also chargers available with 2.0 mm plug of course - like the AC-3 and the AC-4 - but getting another charger just for the headset would probably constitute overkill...
Thanks. Have persevered and finally found a Nokia Service Centre that claims to have persuaded Nokia UK to bring the part in from Finland. They have ordered the part in - should be available to me in ~7 days. Will post details here when/if it becomes a reality.
Finally arrived from Fonefix. They have some more in stock now. Contact details are:
FoneFix Limited
15 Foss Islands Road
York
YO31 7UL
United Kingdom
t : 01904 689 999
e : [email][email protected][/email]
www.fonefix.com
