Nokia 6630 Question
4 replies · 1,598 views · Started 05 October 2005
Hi i just got my SimFree Nokia 6630 yesterday which i orderd from mobilefun.co.uk
I have noticed that when ever a sound is played on the fone eg txt message or the camera sound it makes a "pop or click" before and after the sound is played
This is kinda hard to explane so ive recorded 3 sound clips:
Silent if my fones on silent and i get a txt it should not make a sound at all but it still makes this pop sound..
Normal The pop sound can clesrly be heard before and after a txt is recived
Camera You can hear a pop noise before the camera sound effect is played and after its finished when taking a picture.
Is this normal for a 6630, i no its a small thing but its REALLY getting on my nervs
Thanks for you time 😊
Matt
Xtreem wrote:Hi i just got my SimFree Nokia 6630 yesterday which i orderd from mobilefun.co.uk
Hi Matt
That doesn't sound right to me mate.
If I'm playing MP3s through the car stereo, the phone gives a digital click as a new track starts, but that's all. The noise of the key tones also generate a click so I have a silent profile selected when using a "headset". Probably due to the amplification.
But there are no clicks in normal use like you're experiencing.
What happens when you play MP3s?
Chris
When i play an MP3 it makes the click sound when it starts playing then again when it stops, ive formatted the fone and it still happens
Xtreem wrote:When i play an MP3 it makes the click sound when it starts playing then again when it stops, ive formatted the fone and it still happens
What software are you using to produce those mp3 files? Maybe you are putting headers that the phone decoder doesn't understand so that part of the file is played as if it were part of the data in the file.....
UA
Utenteanonimo64 wrote:What software are you using to produce those mp3 files? Maybe you are putting headers that the phone decoder doesn't understand so that part of the file is played as if it were part of the data in the file.....
UA
The phone makes this sound even when not playing an MP3... but there encoded in nero.
So what can be causing this noise? it really annoys me so the 6630 aint ment to make it right...
