I have the ST Micro Bluetooth Device with BlueSoleil 1.4.9.6 Release 050322 under Windows Xp SP1. The problem is that when i try to connect to my Nokia 6670 via Nokia Pc Suite 6.6.18, i get the following error: Cannot use the connection type. Check that all the needed hardware, software and drivers are available. (Code: OpenMedia).
If i use only the drivers for bluetooth (not install BlueSoleil), my Bluetooth dongle is detected in Device Manager but not by Nokia Pc Suite.
Please tell my what is the sollution for this problem. I want to use bluetooth connection as i used the data cable (USB DKU-2) connection. Thank you!
Bluetooth, plsss help!!!
I remember the PC Suite pages (http://www.nokia.com/pcsuite) stating that you need version 1.6.* BlueSoleil drivers. You stated you have version 1.4.*, which might not work, then.
Or upgrade to WinXP SP2 and try Microsoft's built-in Bluetooth drivers in SP2.
I solved that problem, it was driver version older then PC Suit required. But i have another one. Now it detects the phone i pair it with the computer. And the PC Suite status is Not Connected. I tried with another 2 computers and it's the same. But with a Nokia 6230 worked fine. What should i do? Could be a phone software problem ?
