Use bluetooth internet on your 7610\6670\3230\6260
7 replies · 1,497 views · Started 06 October 2005
As I said in another thread today this is solved at Xan site.
If you have a 6630 / 6680 / 6682 you are in luck today.
Xan has made Gnubox work for all these phones.
Full TCP/UDP stack and PPP protocol are now available, Opera 8 and AgileMessenger works. Other Apps may also work if they allow to
select Bluetooth as an AP.
Bye,
N66x0
well guys.. i tried this with my 7610 and everything went as stated in the tutorial throughout but then.. i think i have a firewall problem or something.. im sure this will work though!
Please someone post links to make this work!
Caio Montalvo wrote:As I said in another thread today this is solved at Xan site.
Bye,
N66x0
I will appreciate some step by step instructions...... First of all I can't make a CSD/data connection on my 6630 so at that point I must deviate from the instructions on the site from Pakistan..... I installed gnubox on the phone, I tested the serial connection and I could see the incoming connection in the pc bluetooth stack. But when I try to use Opera (configured to use access point Bt) it still tries to go over a GPRS connection, whick makes sense as I am forced to define any access point on the phone as GPRS.
So as I said detailed instructions would help........
UA
