6680 or 6681 ??
4 replies · 1,442 views · Started 07 October 2005
Hi, I can't seem to decide between these two phones. Can anybody please tell me the pros and cons of each phone ?
Also I want to know can I install office applications (like word and excel viewer) on 6681 ?
6680 if you need 3G (=WCDMA =UMTS) and want the front-camera. 6681 if you can live without 3G and video calls. Both run the same software/apps.
N/A wrote:6680 if you need 3G (=WCDMA =UMTS) and want the front-camera. 6681 if you can live without 3G and video calls. Both run the same software/apps.
Does both of them have flash ?
It depends on what "flash" you mean when you say "flash". 😉
Do you mean a camera flash (bright light)? If so: Yes.
Do you mean so called Flash memory? If so: Yes.
Do you mean Flash as in Macromedia Flash or Flash Lite software? If so: Probably not built-in (unless an operator variant where the operator has put it in), but you could buy a version of Flash Lite from Macromedia, I think.
