Battery out Looses Time
4 replies · 1,937 views · Started 07 October 2005
Simple question in the absence of other 9500 owners around... If you take the battery out and put it straight (3-4 secs) back in, is it normal to loose date, time etc... I could swear this was not happening in the beginning (now it does) but the local Nokia says it is normal behavour. Is it? (i.e. no small internal battery whatsoever?)
Thanks,
Gregory.
http://www.grema.com
gmantzar wrote:Simple question in the absence of other 9500 owners around... If you take the battery out and put it straight (3-4 secs) back in, is it normal to loose date, time etc... I could swear this was not happening in the beginning (now it does) but the local Nokia says it is normal behavour. Is it? (i.e. no small internal battery whatsoever?)
Thanks,
Gregory.
I've never had this on mine,
I usually leave the battery out 10 - 30 seconds and have never lost the time or date,
Carl,
CJackel492 wrote:I've never had this on mine,
Carl,
Thank you,
I thought this should be the case so I took it to the NOKIA service center and they told me it should loose the time. To demonstrate they showed me one of theirs which lost it when the battery was taken out. Maybe I will try to take it to another center but this is really strange...
Any other experiences most welcomed...
Thanks again!
Gregory.
gmantzar wrote:Thank you,
Thanks again!
Gregory.
Acutally my 9500 does that when I take the battery out...
im also having this problem. I asked a friend if his resets and he said that it doesnt. does the 9500 have a cmos or back up battery like what desktop and notebook computers have?
Would love to hear from anyone who is experiencing this.
