Problem With Bluetooth
4 replies · 2,022 views · Started 13 November 2002
Sorry i know there loads of posts on this but im having a problem with my bluetooth when i try to connect to my pc Via TDK USB Adapter it asks for the passcode is there a default or somin coz i havent set one as far as i know.
Thaniks
simply enter _any_ number, press ok, then a popup will appear on the other device where you have to enter the _same_ number... so no matter which number you choose, just make shure to enter the same on both devices...
should work when entering the same numbers on phone and on notebook.
e.g. you are trying to establish a connection from the notebook to the phone - then the phone asks for a code - enter 1111 - next thing is that the notebook asks for a code - also enter 1111
viola, you are paired...
at least that's the way it worked with my collection of bluetooth devices....
Yup, that's how it's supposed to work 😉
