Hi All,
I have the Tom Tom in a folder on my PC. I tried to send it from my PC to my Phone, but the phone didn't accept it as a folder. So I sent the files one by one around 49 or 50 files. Is it that many files? Anyway the files are in the inbox, so I moved them to My Folders in a folder called TT that i created. Anyway the files have extensions like .chk and .22k and .vif and .exe. They all are unkown file format even the .exe. So we can't run the .exe on Symbian???
Guys, can you please help me on how to install Tom Tom.
Buzzer wrote:Hi All, I have the Tom Tom in a folder on my PC. I tried to send it from my PC to my Phone, but the phone didn't accept it as a folder. So I sent the files one by one around 49 or 50 files. Is it that many files? Anyway the files are in the inbox, so I moved them to My Folders in a folder called TT that i created. Anyway the files have extensions like .chk and .22k and .vif and .exe. They all are unkown file format even the .exe. So we can't run the .exe on Symbian???
What happens when you simply put the original DV RS-MMC card from TomTom into your phone?
Steve
slitchfield wrote:What happens when you simply put the original DV RS-MMC card from TomTom into your phone? Steve
I think thats what your supposed to do, remove your original DV-RSMMC memory card and install the Tom Toms as it contains the maps. It probably has some sort of protection to stop the copying of files as the maps cost around �99 usually on DV-RSMMC.
I copied Tom Tom navitor to my PC then to my new 512MB DV-RSMMC, and
now I can't install it on my phone anymore.
What should I do???
Quakester2000 wrote:I think thats what your supposed to do, remove your original DV-RSMMC memory card and install the Tom Toms as it contains the maps. It probably has some sort of protection to stop the copying of files as the maps cost around �99 usually on DV-RSMMC.
Just buy the original software and stop using illegally downloaded versions. Especially as the version you have is not even the smartphone version.
😡 😡 😡 :banghead: :banghead: :banghead:
