Voice Commands Corrupt
1 replies · 1,822 views · Started 08 October 2005
😮 Hi Guys,
Previously I was playing around in File explorer, and I think that I deleted some important files, because my voice commands aren't working now. It tells me to Press Start and speak after the tone, but when I do that it says Voice System Error.
Can Anyone help me here................
I had this problem and a solution was posted by another user.
Reformat your phone at your own risk using *#7370#.
It should ask you to restart and will be back to like the day you bought it. Using restore original settings from the phone menu does not do a full format or reverse this error so you must use the manual format code. Note you will loose all personal datat on the phone memory (contacts, programs etc) so backup your contacts to the memory card and remove it before formatting.
